At least this 20k rated supertech is $19.98 at walmart which is about what it's worth and what i paid for it as it's the cheapest synthetic. Strangely the 10k variant got bumped up to $21.47.
That or quaker state next time. Pennzoil full syn seems a bit less good in voa's and doesn't have a dexos approval but quaker state looks better and is d1g3 approved already. Only a buck more so it's worth getting. May get valvoline full syn as well.
Pennzoil Platinum is Shell Helix Ultra SP and has the Dexos 1 Gen 3 approval. The Ultra Platinum is all GTL, and doesn't carry Dexos. The VOA is irrelevant. I'd skip the Quaker State and go for either Pennzoil because they have a much more expensive additive package and base oils.
Shell recently had a breakthrough in their GTL process, so their base oils vastly improved, and NOACK is much lower. It's good stuff, use it with confidence. If not, there is always Mobil 1.
Mobil 1 EP 5W-20 and change it once a year. Before I joined BITOG, that's what I did on all our vehicles. Without thinking twice about it, it was always a viscosity of Mobil 1 Extended Performance and OEM filter. After I joined BITOG, I picked up some bad habits, like trying out new motor oils. Yes, all the majors make good oils. I like Mobil, Pennzoil, and Castrol, in that order. Kirkland (Warren) isn't as good as Mobil 1 or Pennzoil. Don't lose any sleep over it.
I'm 100%, but from the SDS it appears that Mobil 1 5W-20 vanilla is identical to Mobil 1 EP 5W-20. Mobil made these oils so good that it's become harder to create segmentation between them. That's not the case for every product though. Mobil 1 EP 0W-20 is a unique product made from PAO and ANs, without viscosity improvers. It's cheap for what it is.
