JHZR2
Staff member
Hi,
as some might recall in my post a month or two back in the maintenance and repairs section, my 91 E30 BMW 318i developed a coolant leak to overboard, through the headgasket.
I had it repaired, no problem. The shop put Agip 5w-30 in it. I noted that they put in oil that was too light, and they offered to change it on the spot, but I figured they were going to do it in 1000 miles when I bring it back to be re-torqued, and it was a good chance to run auto-rx.
I use the car to commute, and am very light on the throttle, plus my commute is only 8 miles, barely enough to heat the oil up, so I figured it was OK.
Tonight I was out running errands, and had to use the throttle. I didnt floor it, but I was at about 2/3 throttle, and about 3500-4000 RPM. I noted in my rearview something that I had never seen before... a cloud!
Now, my only possible reason for a cloud seems to me to be because Im running oil that is too light, and is vaporiing/buring. THis never happened with 5w-40 (40-50wt being specced for the 1,8L M42 engine).
But that said, is this an indication that the oil is just plain too light, and should be changed out even sooner rather than later? I have about 500 miles left before I have to take it in to be retorqued... Should I bite the bullet and do an oil change ASAP? Or should I just drive it gently as usual, avoid highway driving and acceleration, and call it OK?
Thanks!
JMH
Thanks!
JMH
