Fuchs Titan GT-1 0W20 has been here for some time. Having trouble getting specs from Fuchs Oz distributor though.
So they can't get away with using xW-20 oils for turbocharged OHC small displacement engines - but why is that?quote:
Probably because different applications require different weights. If auto manufacturers can get away with a thinner weight to save fuel, they will. If they can't...
Silkolene is Fuchs motorcycle oil brand - most likely why you find them in bike shops.quote:
Originally posted by Jay:
Rexman, thanks for the links. Fuchs' oils are sold in the US under the Silkolene name, including their 0w-20. It has all ester basestocks. I've seen their oils in motorcycle dealerships.
unDummy, you can find the viscosity info you were referring to by playing with this neat viscosity calculator.
My mechanic says these engines seldom go above 210 F. The cylinders banks rest 180 degrees from each other, so they dissipate heat very well-- plus the aluminum alloy engine block and special oil cooler help too.quote:
Originally posted by unDummy:
I'd love to know what the oil temp in all those turbo Subarus. Does Sube use coolant to cool the turbo? Are they using ballbearing or bushing type turbos?
Look forward to hearing the results on the 5W50 Supersyn, although I am beginning to think the Fuchs products are pretty "magic." Just curious, in an automobile engine, how long do you think the "plating up" process would take?quote:
Originally posted by sprintman:
Rexmam my mate Ron in Melbourne ran Titan GT-1 0W20 on his Timken last night. Handled 140lbs pressure which is incredible. Not great on first run from cold but whatever the anti-wear is ZDDP, Moly or whatever, 2nd run from cold fantastic. Must be 'plating up'. The 10W30 excellent too. Doing the 5W50 Supersyn (yes Supersyn) tonight.
