505.01 oil for '03 Audi RS6
505.01 is a very specific oil from the 502/505 oils, which made for higher shear engines, in particular, at that time the Pumpe-Duse TDI's, that were prone to cam wear, vs using a regular 502/505.00 oil.
So, I would probably say no.
505.01 was mandatory for 4.2 twin turbo RS6
That's because no other specification oil was available enough for it, as I believe in Europe, it 506.01 was required, but there's no inventory for that in the USA and not worth to build the inventory for a limited engine, so 505.01 was close enough and VW sold a lot more TDI's to justify it.
If "Advanced MST" is same as "Synpower MST":
It comes or came with VW 505 01, 502 00 and 505 00 approvals, so it should be good enough.
Does that "Valvoline 1 European Car Formula Motor Oil 5W40 Full Synthetic European Formula"
sold at NAPA even come with any approvals?
I'm surprised some saying VW/Audi did spec VW 505 01 and 506 01 oils for gasoline engines in
the US. In Europe at least these approvals apply exclusively to (Pumpe-Düse) TDI engines only.
I had one of those PDs. Ran excellent for nearly 150k miles then I sold it. I did not take measurements of the cam but I did at least take the valve cover off and snapped a few pics. I could detect no abnormal wear, such as rounding of cam lobes, bowling of the lifters or spiderweb cracks on their surfaces.
I mostly ran 505.01 oil, but switched to 507 when it first came out (man, it was pricey) and also had a Amsoil bypass oil filter kit setup.
The several Blackstone UOAs I did came back excellent, saying I could run that oil safely to 15k miles. And most of the time, I did.
