You’re luckier than I am. I feel like I visited a prison on shower night, with a 36 gallon tankYou're right. I feel serviced every time I fill up.
A gas pump services all vehicles at the same rate
My FXT gets MAYBE 330 miles per tank. My Legacy gets 450. What is your point, exactly?
YupF150? My last vehicle was a 36 gallon 2017 5.0. It was painful when I ran that tank down.
Are they both still 15.9 gallons? It would take same time to fill both. EVs even of same battery storage take varying times due to batteries used, charger capabilities, and temperature effects. It was simply a math point on “charging” times of gas vehicles compared to EVs.My FXT gets MAYBE 330 miles per tank. My Legacy gets 450. What is your point, exactly?
Unless your rollover valve fails and the fastest you can pump gas into the tank is about half a gallon per minuteA gas pump services all vehicles at the same rate
The only variable in filling a gas car is the flow rate of the pump in the ground. Fluid flow vs. electron flow.
