Originally Posted By: thrace
Originally Posted By: JerryBob
The oil in my truck is 4 months old, but only has 2000 miles (I commute on train).
Getting ready to take a round-trip to Arizona and Colorado, and I am inclined to change the oil with fresh TGMO, but leave the filter in place.
I'll probably do some off-roading while out there, but nothing extreme. Just getting to remote trailheads.
Thoughts?
Got two trucks in the sig. Presuming you are taking the Taco. In that case, agree with most. No need to change. Take a few quarts to keep the level up. Make sure fill area is clean, if adding, to reduce dust. Make sure air filter is not leaky.
If it is the Honda, change the ATF, preferably with a suitable synthetic. Consider changing the ATF filter and adding an ATF cooler if not done. But certainly do not use that bad old Z-1 if there is any leftover. Lots of available junkyard Honda engines of that era because the transmissions break so often.
The Honda is an Odyssey minivan that the wife drives. I have been lucky with the tranny so far. I run Amsoil synthetic ATF in it now. I've read different things about changing the ATF filter - as to whether it is feasible. Probably beyond my skill level, too.
But the engine timing belt slipped at 1,500 miles (not a typo) due to a faulty tensioner. Still po-d at Honda for their attitude about it.
