Just got back my 3rd analysis and it was worse than my last one. This was 5W-30 Mobil 1 Tri-synthetic. Oil had 3,010 miles on it and truck had 40,546 miles on it. Blackstone labs did the analysis. Here is what they said in their comments section.
WAYNE: We were hoping we'd be able to tell you that bearing wear and silicon improved, but they did not. Lead is not as high as it was in August of last year, but it's still higher than average and we're not sure why. If the silicon is abrasive dirt escaping air filtration, that could be affecting bearing wear. Suggest checking air filtration for leaks. Otherwise, we think you should stay at 3,000 miles and check back with your next oil change. Insoluables were on the high side at 0.5%. The TBN read 12.5, showing plenty of active additive left in the oil.
Aluminum--4
chromium--3
iron--18
copper--5
lead--43
tin--5
molybdenum--3
nickel--1
manganese--1
silver--0
titanium--0
potassium--3
boron--57
silicon--28
sodium--7
calcium--861
magnesium--1432
phosphorus--621
zinc--766
barium--0
SUS viscosity@210 F--61.8 (this is slightly outside normal range)
flashpoint in F--420
fuel%-- antifreeze%--0.0
water%--0.0
insolubles--0.5
As far as my silicon readings go, I have checked all my intake duct work and can find nothing open. Everything seems to be sealed good.
During this oil run, I pulled a loaded utility trailer a few times and used Chevron Techron fuel system cleaner and GM Top engine cleaner. I don't know if these factors had anything to do with my lead levels, how much insoluables were in the oil, or my increased viscosity. As before, I'm not sure what to think about this oil. I think I will probably try a different brand of oil and see what happens.
Do you guys think that this oil is not providing enough protection for my bearings or am I experiencing the beginning of a mechanical failure?
Wayne
Aluminum--4
chromium--3
iron--18
copper--5
lead--43
tin--5
molybdenum--3
nickel--1
manganese--1
silver--0
titanium--0
potassium--3
boron--57
silicon--28
sodium--7
calcium--861
magnesium--1432
phosphorus--621
zinc--766
barium--0
water%--0.0
insolubles--0.5
Wayne
