Got some SAE or similar valid links that show this claim?
Quote Amsoil
60% of total engine wear occurs during cold start up
conditions before oil can circulate through the engine...
Quote Lake Speed Jr certified lubrication specialist at Driven Racing Oil.
“While a thicker viscosity grade is a workable solution, remember that
70 percent of engine wear occurs at start-up, so a higher viscosity
grade actually causes more wear, and we have used oil analysis that
shows this,” says Speed.
Quote 540Rat
"Thinner oil flows quicker at cold start-up to begin lubricating
critical engine components much more quickly than thicker oil can.
Most engine wear takes place during cold start-up before oil flow can
reach all the components. So, quicker flowing thinner oil will help
reduce start-up engine wear, which is actually reducing wear overall."
Quote Frank McCowan, former Electrical /Mechanical Small and Large Equip.
Mech at Washington Metropolitan Area Transit Authority...
Listen to Jim Trainers answer below, it is mostly accurate. most
engine wear occurs during not only the first few minutes, but in the
first few seconds from when the engine is started.
Quote Jim Trainor, diy car maintenance guy
"The oil pressure takes a moment to come up and it takes a moment for
the oil to start circulating. There are bearing surfaces in your car,
called “journal bearings” that are quite literally two pieces of metal
separated by a film of oil that is delivered in under pressure in a
continuous flow. These surfaces do not touch when the engine is
operating normally. Other bearing surfaces, such as cam followers, and
piston rings, do touch but are subject to a continuous flow of
lubricating oil. When you start the car there are a few moments where
the oil is absent from these surfaces. Hence increased wear occurs."
Quote EAA ( Experimental Aircraft Association)
"When we first crank the engine, there's no oil pressure and the
crankshaft cranking speed is pathetically slow. The conditions for
hydrodynamic lubrication simply do not exist. Consequently, there is
metal-to-metal contact between the journal and the bearing, and wear
is inevitable."
The point of the photo is to graphically show the different rates of
flow between 0W 5Wand 10W... On a day with outside temp of 104F the 0W
still flows quicker during start that either 5W or 10W...
