- Messages
- 186
- Location
- An Alberta Garage
Statistically they all look the same. The only conclusion I draw from this analysis is that the 1.8T is one heck of an engine from a materials perspective. ![[I dont know]](/forums/graemlins/dunno.gif)
quote:Spitman, You are probably correct. But to know for sure, we would need the standard deviations so here they are: Wear Xw-30 oils (Xw-40 oils) Alum 0.43 (0.35) Chrom 0.08 (0.09) Iron 1.40 (0.95) Copper 1.01 (1.43) Lead 2.56 (0.37) Tin 0.14 (0.10) #obs. 12 (17) For the Mobil, they are: Wear 5w-30 (0w-40) Alum 0.28 (0.26) Chrom 0.07 (0.09) Iron 1.38 (1.46) Copper 0.80 (0.56) Lead 0.40 (0.24) Tin 0.15 (0.07) As you probably noticed, many of these standard deviations are really high relative to the means which does indeed suggest no statistical difference in means. Just the same, I did some ttests, and the only significance difference I can find was that iron under M1 5w-30 is lower than iron under m1 0w-40. But it is significant only at the 10% level. Then again, getting any significance at all is surprising given the small sample size so there may be something here with the iron.
Originally posted by SPITMAN: Statistically they all look the same. The only conclusion I draw from this analysis is that the 1.8T is one heck of an engine from a materials perspective.![]()
quote:Also did the test for lead comparing 30 weights to 40 weights (all samples, not just the mobil 1 samples) and found that 40 weight lead is significantly lower than 30 weight lead only at a 13% significance level. But given the small sample size, this isn't bad so you may be on to something Patman
Originally posted by Patman: Looks close to me on most things, but bearing wear (lead) is greatly improved with 40wts! For that reason, I'd go with the 40wt in those engines for sure.
quote:yep!
Originally posted by pscholte:quote:Thanks...guess I need to root for the Buckeyes today, huh?
Originally posted by sbc350gearhead: Pscholte......long time no see.![]()
quote:Thanks for your thoughts TooSlick. Couple more questions: 1. I noticed that people tend to favor the 0w-40 because of the VW 50X plus ACEA A3 ratings. How important are these IMO and is it enough to offset the shearing concerns you mentioned? 2. If VW is strictly interested in fuel savings, why would they recommend 5w-40 over 5w-30? Of course, Audi has dropped to 0w-30 now so I see inconsistencies here. I get mixed signals about whether they are trying to protect the engine or protect fuel economy. Do you have any insight about this? Thanks.
Originally posted by TooSlick: VeeDub, VW and Audi don't specifically recommend 10w-30/10w-40 for their current crop of engines, but that's tied to saving 0.5% in fuel efficiency with thinner grades. Unless you live in Alaska, a 10w-30 or 10w-40, PAO/Ester based synthetic will provide excellent year round performance.
quote:Hmm, so you'd rather use an oil that doesn't meet the VW-mandated minimum requirements to begin with? There are a few 5W-40 oils available in the US that meet VW 502.00: - Pentosynth 5W-40 - LubroMoly Vollsynthese 5W-40 - Unocal 76 Pure Synthetic Oil 5W-40 I don't think Redline 5W-40 would harm your engine either.
Like most 1.8T drivers, I've been using Mobil 1 0w-40 since it became readily available but will be switching to Mobil 1 5w-30 and 10w-30 for better shear stability.
quote:AMEN! Pretty clear conclusion to me there as well. Lead is one of your major indicators and bearings are the first indicator of an engines health. Fred...: )
quote:Mobil 1 0w-40 meets VW 502 but according to some UOAs here, it's not as shear stable as 5w-30. For the rest, I'm aware of them but they're not easily available and more expensive. I rather spend that money on other mods.
Originally posted by moribundman: Hmm, so you'd rather use an oil that doesn't meet the VW-mandated minimum requirements to begin with? There are a few 5W-40 oils available in the US that meet VW 502.00: - Pentosynth 5W-40 - LubroMoly Vollsynthese 5W-40 - Unocal 76 Pure Synthetic Oil 5W-40 I don't think Redline 5W-40 would harm your engine either.
