30,000 miles AMSOIL 5w30 1993Taurus SHO
miami fl
here are results of my brothers car I ended up with after my 1991 SHO was stolen from me last sept. We bought the car in 2004 and added AMSOIL into the engine and from all the upkeep after buying a used car we just never felt like changing the oil, it used/leaked a quart every 1000 miles, just a few months ago the car quit running and I had to change all the sensors and I fixed the leaking cam sensor seal that was stealing all my money. so now the oil stays put, I am posting up the results from it's first UOA and I wonder if I need to change the oil? from the results I dont think I need to. One thing I may need to change with this particular engine is the Rod bearings , since these engines are known for beating them up. well here we go Aluminum 3 Chromium 2 Iron 20 Copper 7 Lead 36 Tin 3 Moly 48 Potassium 2 Silicon 7 Sodium 9 Calcium 3077 Magnesium 15 Phosphorus 672 boron n/a Zinc 828 cST Viscosity @100 10.9 no tbn with this sample with more than 30,000 miles on this oil and plenty of fresh quarts added in over the years this oil will stay in the crankcase
lazaro
miami fl
 Originally Posted By: dave123
With 30 fresh QT's you spent more on oil than the car is worth.
ouch! but I agree! still I will not change the oil and the leak I had is gone, so far 900 miles and it is stil in the cross hatch and that is with me pulling a sample too. at least 10 oil changes is something I can skip on I spent it at the Beach, the track, on the road! LOL not at some Jipme lube! LOL!!
CA.
Makes you wonder if at lets say 6000 miles you change out the filter and 2 qts of oil. Call it a partial OC, that is one of many possible combinations. How long can an OCI be stretched doing something along those lines? AD
lazaro
miami fl
this is why I took this oil sample, now that I fixed the oil leak in due time I will get a better UOA with a TBN and NIT OXI reading to better understand the oil condition. I could add a bypass but I dont really like this car, I want a 5 speed, I hope the bottom feeder brings my old car back one day anyway I did change out the SDF oil filter 2 years ago and added a EAO, it is still on there, and for the duration it had an old stlye AMSOIL air filter that I just swapped out for a EAA filter. looks like I was doing just fine!
Western Washington
The title you used for this thread is deceiving. You did that for attention/shock value so that people would read it. There is no value in this to others. You're nothing but an attention whore.
USA
with 30 qts of makeup, this sample doesn't have 30k miles on it. if your sump is 5 qts, just the 30qts of makeup, that's six oil changes. I would have used supertech until the oil leak was fixed.
lazaro
miami fl
maybe you are right? I wanted to be the first to post up a UOA that was different than the normal ones posted here. Maybe it does not float ur boat but there is nothing decieving with the title, I have not drained any oil for 3 years and I have had to add to my engine every 3 months, Im sure there are plenty of people in my boat having to add oil as they go. thanks for your vote of confidence anyway!!!
PA
Wow, tell us how you really feel. I for one am impressed with the metal numbers. I'd like to see a TBN but it is probably fairly high.
lazaro
miami fl
10 oil changes would cost $200 in oil alone not to mention the time at wally world or you laying on cardboard. I was at the beach or driving some place, I dont worry about oil changes!
lazaro
miami fl
if you cant fathom it then it just cant be true and they have to be a troll! LOL! you must feel Threatened everytime I post anything positive about AMSOIL your so silly!
Illinois
It's just that this is not a true indicator of how the oil performed with so many new quarts added. You're just so over the top Amsoil. It's a VERY good oil, no doubt, but come on...you're just SO Amsoil nutty. If I were a dealer on this forum I'd want to scream. I'm done...
Canada
It's impossible to tell if this is a 'good run' or not. Wear metals are low, but with that much make-up oil, its just been 'flushed out'. One thing I will agree is that your bearing wear is high - its not 'supposed' to be higher than iron, or you have a wear problem from too low visc., or so I've read. In Forida, I'd change the oil to 10W-40 and see how it does.
NJ, USA
It's good enough for him so who cares what anyone else thinks?
OVERKILL
$100 Site Donor 2021
Ontario, Canada
OK. Now, if somebody was doing 5K OCI's using conventional on this car, that is six oil changes, as Cutehumor pointed out. I just checked Amazon.com, and I could buy a case of TWELVE litres of Valvoline 5w30 for $32.28. So, 30L of Valvoline would cost $80.70. Add a Motorcraft filter for $4.00, or six of them for $24.00, and our grand total for SIX oil changes is $104.70. Now, for an average Joe without PC or dealer pricing, 30L of AMSOIL is going to cost $262.50, and that's without shipping. And no filters. Even using dealer/PC pricing, the 30L of makeup oil cost you more than TWICE what six oil changes would have cost within that time frame. Lying on the beach or otherwise, you spent an [censored]-load of money on make-up oil and I bet there was just as much work involved opening the hood 30 times to add oil to that beast as there would have been changing it six times too.
