It's an H8 in the Mercedes S550 I bought. Charger kicks off after 15 minutes and the battery is at 5 volts. What are the chances AutoZone will comp me a new one without the receipt?
Autozone should be able to check everything in their computer system based on your phone number.
Oh okThe battery came in the used S550 atikovi bought.
Do I detect a "made in Germany" white sticker on the top by the negative terminal? Could you post a clearer picture of it?
I don't know if your Mercedes needs it but there is probably a BEM code somewhereYes made in Germany sticker.
I've got more daunting codes to deal with first in the transmission.I don't know if your Mercedes needs it but there is probably a BEM code somewhere
Clarios bought out Varta Automotive, I've noticed as of late most of the Clarios AGM batteries seem to be coming from Germany.Do I detect a "made in Germany" white sticker on the top by the negative terminal? Could you post a clearer picture of it?
