Some were the Mitsu's but you also had some of the Chrysler engines as well. Then there was the sludger 2.7L's
I honestly don't remember any of the Chrysler-branded ones being bad for oil burning
But yes, there was that sludge beauty of a 2.7L!
The minivans with the dying tranmissions and smoking Mitsubishi 3.0L's in them were a nightmare combo that definitely gave those vans a reputation!
Although it says Chrysler it's actually a Mitsu. It would have been a great engine if Chrysler listened to Mitsubishi and went with proper valve seals. They had this same engine variation in Mitsu branded cars with proper valve seals and it didn't burn oil.
That's the notorious 3.0L
Curious about this "proper valve seals" comment, since oil consumption in Chrysler products had never been an issue and wasn't an issue with any of the Chrysler designed engines. Did the Mitsubishi engine require exotic valve seals in order to not become a mosquito fogger?
The Wiki on it:
https://en.wikipedia.org/wiki/Mitsubishi_6G7_engine
States:
Quote:
The 6G72 was manufactured in three different models which featured SOHC with 12-valves, SOHC with 24-valve, and DOHC with 24-valves.
The latest version was used in the Mitsubishi Eclipse GT and Galant. Output in 2004 was 210 hp (157 kW; 213 PS) at 5500 rpm with 278 N·m (205 lbf·ft) of torque at 4000 rpm.
In the older version, used in many Chrysler models since 1987 this V6 was a SOHC 12-valve developing 141 hp (105 kW) at 5000 rpm and 172 lb·ft (233 N·m) of torque at 3600 rpm. The Mitsubishi models were with a 3.0 Litre 6G72 engine SOHC 24-valve developing 195 hp (145 kW) at 5000 rpm and 205 lb·ft (278 N·m) of torque at 4000 rpm.For the MIVEC engine output is 201 kW (273 PS; 270 hp) at 6000 and 304 N·m (224 lbf·ft) at 4500.
The SOHC 12-valve for the second generation of Pajero can provide 109 kW and 235N·m,the SOHC 24-valve can provide 133 kW and 255N·m.
The DOHC 24-Valve was used in the Mitsubishi Debonair, 3000GT and Dodge Stealth producing 222 horsepower (166 kW) and 205 pound force-feet (278 N·m) of torque in naturally aspirated form, and as much as 320 horsepower (240 kW) and 315 pound force-feet (427 N·m) of torque in turbocharged form.[2] Each bank of the V6 had its own independent turbocharger and intercooler. Turbo chargers were built by Mitsubishi. They were water cooled to ensure longer service life.
Which would seem to imply that the fogger version was specific to many Chrysler vehicles, whilst the Mitsubishi ones had different heads and camshaft arrangements save for the one found in the Dodge Stealth, which, I don't recall ever seeing one burning oil like the vans.
