Just bought a Mazda 91 626 LX with A/T on eBay.
After replacing radiator, pretty much all is ok: a little chip in windshield, a little quirk in ABS, just minor stuffs.
Except, the ATF was like used engine oil when bought.
I had the same model (92) 4 years ago that had the failing tyranny at 135K before being totaled. So, I'm very paranoid with A/T. There is nothing wrong with shifts on the car's A/T so far. Thank god.
So far, I have done:
1. Had mechanic replace a/t filter, change pan gasket and fill 4 quarts. (brand of fluid unknown, also noticed the mechanic did bad: 3 nuts loose in the pan). Also mechanic overfilled 1 quart. Did not check filter. But, checked the gasket and noticed it was indeed changed. Full capacity is 7.2 quarts.
2. 200 miles later, I drained again, myself this time. (Filled with Maxlife HM DexIII, 3 quarts). About 0.2 inch (1/4 quart) overfilled.
3. Another 200 miles later, drained again. (1/2 quart Maxlife, 1 quart Mobil1 ATF, 1 quart SuperTech DexIII). ATF level is right on.
4. Now, the color is a little bit darker red, but clear and nice.
So far, after the third change, the car seems to have better power, smoother shifts and made most noticeable difference. Due to M1? New fluid? ST? I don't know.
Anyway, since ST DexIII is so cheap at $1/qt, I'm thinking I will just change (drain refill, replacing about 35%-40%) ATF along with my engine oil at around 3-4K miles and filter change at 12K miles. I might even put M1 ATF everytime, since I save a lot in labor. No T-Tech due to high cost and some risk. Probably no external cooler will be installed either since I don't want to do it (a little risky) and I have been ripped by a lot of mechanics.
The same mechanic charged me $20/bottle for FI cleaner x 2 to fix a hesitation problem, didn't fix. Came back, replaced battery and it is better. At $40 FICleaner + $60 labor, I would have ordered FP/LC & ARX if he had told me that's what he was going to do. Another mechanic quoted me $2200 for headgasket, waterpump, timing belt, radiator AFTER he found out how much I have paid for this car
Anybody think my plan for mostly-bad Mazda's AT is overkill?
