Hello Everyone. I am new to this board and I must say I can't stay away. I keep logging on at work and may soon be fired . I have a 2003 Mercury Sable with the Vulcan 3.0 V6 engone. I bought the car used with 9000 miles on it. I couldn't sleep thinking about using 5w20 oil, so I went ahead and did my first oil change with Mobil1 5w30. (I drive about 600 miles per week, so I need the engine to last.) Soon after the first Mobil 1 oil change, I began seeing about a tablespoon of oil on my garage floor each morning. I would wipe it up, and it would reappear the next day. I made sure everything was tight. (plug, filter etc..) The leak persisted. This went on for a couple of months and I finally decided to take it to the dealer. I did a quick oil change with Motorcraft 5w20 first just to be sure that if I blew out a seal, that they would not figure out that I had not followed the 5w20 oil reccommendation. Anyhow, first they put a new filter on it and told me that a service bulletin stated that I needed to tighten the filter an extra 1.5 turns. I told them that the leak was not from the filter, but I think it was oily in that area because of the recent oil change. Of course, it still leaked and I brought it back again and they discovered that the oil pan gasket was leaking. They replaced it under warranty and it now does not leak. OK..... Sorry about all the reading, the question is.. Could the use of the Mobil 1 5w30 have had anything to do with the leak? It did not appear until I changed the oil that first time. I would like to go back to using it. (5w20 still gives me the sweats.. it took me years to try 5w30). I know that it does not seem likely, but it seems like a weird coincidence that the gasket failed at the same exact time as I switched to the synthetic.
Any advice would be welcome.
Rob
Rob
