Some 2AZ-FE engines will leak coolant externally because the block has a bad casting & the head bolts lift off. The fix is a time-sert on the 3 inner rear headbolt areas. The outer holes have dowel pins & shouldn't be fixed with time-serts. Use new a Toyota headbolts. There's a TSB for this concern. I've repaired a few & it works quite well.
