Al, You seem to know quite a bit about engine oils. Is 287F not a little high for conventional engine oils especially ones with VI improver in them?
I thought that after 250F dino oils go all to heck in a hand bag in a hurry.
Tyrolkid; do you believe this statment?
On a turbo engine you can move the cam(s) around, which means advancing and retarding them in relation to the crank, and change their lobe seperation with out making much difference to the performance (HP) of the engine as long as the
cam(s) are under-sized. (or small like stock ones)
Next question, and I know that this is off-topic, but so what, its relevant,(just like the Jerry Springer show).
If you increase the intake duration of the camshaft with no other phasing changes, you will open the intake valve sooner and close the intake valve later.
If the intake valve begins to open BTDC and before the exhaust valve is closed, as intake valves often do, the exhaust back pressure is 35 PSI, and the intake pressure is 28 PSI, in which direction will the exhaust gasses flow?
260 HP at 5000 rpm is how much torque?
If you could make that much torque at 6500 rpm, how much HP would the engine be producing?
338? Now were getting 3HP per cid
TBC...
[ September 26, 2003, 07:17 AM: Message edited by: userfriendly ]
