They look pretty good!
As a rule on any plug I install, I gap them .001" tighter then spec, as they age,
the gap burns to nominal and later a little over spec, but the plugs don't miss fire unless
you ignore them for years. I drive 15,000 to 20,000 miles a year, I don't want to
pull them out too often.
Old fashioned Champion spark plugs, etc, I may gap .002" tighter if I know
the engine is hard on them.
I use machine shop feeler gauges with .001" increments, requires
some feel for it.
On long life Iridium plugs with 120,000 miles, I could see under the
microscope the Iridium pad on the ground electrode had finally burned off,
gap was .0015" over spec, but still ran good.
At that point, if left in, the ground would burn back faster in late model
engines with lean fuel mixtures and eventually set a code and shorten the
life of all 3 Cat converters on the car! Not worth it!
I also use a dab of anti-seize paste rubbed into the threads, not engine oil,
or the plugs will be hard to get out 5 yrs later and about 10 Ft/Lb torque,
max to install.
