Back in February I did a bunch of catch-up maintenance on my Uncle's 2005 Toyota Tacoma with the 4.0V6 engine in it. He has only replaced oil+filter and the cabin filter on the truck. Here's what the original copper plugs look like; original gap is 0.043in. I know they are original because of the 2 different brands that Toyota put at the factory (NGK and Denso). The truck never misfired but it was getting about 12mpg on the freeway. Replacement schedule is every 30k miles, but seeing that they went 7.5times their life, why replace them at 30k?
For anyone interested, I replaced/changed
-Mobil 1 HM 5w30 and Toyota Filter
-Toyota Pink Coolant
-Cabin FIlter
-Engine Air Filter (probably original too, had a huge amount of fine dust and the pre-screen was loaded with dirt)
-Valvoline Synpower 75w90
-Trans Drain&Fill with ATF WS (original fluid didn't look too bad)
-Power Steering D&F with Valvoline Dexron VI
-DOT3 brake fluid - full brake bleed
-3 U-joints
-Cabin FIlter
-3 U-joints
