20W50
oregon
Ok my curiosity is running wild. It seems as though the thicker oils are going the way of the dodo bird and that the thin oils are here to stay. But here is my question. Who still uses 20W50 oil? what do you use it in and why? and last but not least would you use it in a vehicle that is under 15 years of age, and under 200,000 miles?
Oahu, Hawaii
I use 20W50 in my 1990 Toyota 4Runner. In the user manual there is a guide to see what oil weight should be used depending on the climate. Since I live in Hawaii, a 40 or 50 weight is used in this truck. Similar from my truck's manual:
TX
We run straight 50 wt in the Cessnas and Pipers I fly I guess it's more ideal for aircraft because they're air cooled which is less consisent than water cooled engines.
Kansas City
Lots of people use it in air cooled motorcycles. I use Maxlife 20w-50 in my 1991 BMW R100. It is the grade that is recommended by BMW. Older BMW cars use it also. I have found that it is getting harder to find at superstores, but still readily at Auto part stores.
Lost in the Garden State
I use M1 15W-50 (20W-50 is specified) in my 1988 Lotus Esprit Turbo. Another reason for non-turbo applications to use it, is that Mobil has increased the ZDDP in it. This is good for the cams and followers. Not as good for the catalyst... I understand that several other brands' formulations of heavier oil now still have ZDDP. Look for the SL spec.
Florida
I used it in my 1986 truck for over 10 years. Worked fine. Even used it with those "restrictive" Pure One filters and without a thermostat! Then again, I live in Florida and it doesn't get below 30 degrees but a few times a year. Would I use it on my nice, new vehicles. Not so much. I think engineering is much better today.
By Detroit
Best use for 20w50 is to thicken your 10w30 in the summer at a ratio of about 1:4, which will bring the modern 10 cSt 30 weight up to an old fashioned 12 cSt 30 wt.
Dallas,Tx USA
^^I noticed my jug of Mobil 1 15W50 silver cap has the SM,SL,and CF specs,but my jug of Pennzoil yellow bottle only has SM spec. What exactly does all that translate to when it comes to the ingredients/additives in both oils? Either one more robust/tougher than the other? The way my car performs with both oils,Pennzoil 20W50 yellow bottle wins hands down.
CA
I run it in the GN and have for many years. Clearances are stockish except for piston to cylinder. It won't live on anything thinner. To clarify, I use this year round and it works great. Believe it or not, the thick stuff eliminated the rod knock I experienced for the first second or two on startup on my older worn engine. It seemed to build pressure quicker on the thick stuff which goes against everything we read about on here.
CA
Just had to say nice car!
By Detroit
Yes, I was more speaking for the average guy, but anyone with a muscle car may need the thicker oil because those engines are whole different animals, different clearances, different temperatures, different stresses, etc.
FL
I have used in 20w-50 my my Rx-7, using Delo 15w40 now because of the robust add pack. \:\!
Dallas,Tx USA
Hey Buick,what kind`ve 20W50 do you run in that beast?
Bad Axe, MI
It's specd(has SL listed) because it has a high level of Zinc in it,but can still be used in SM rated engines.
