- Joined
- Dec 11, 2023
- Messages
- 129
This analysis was done at the same time as my engine oil analysis in my other post. The oil held up, but there was some form of dirt intrusion going on. I wanted to get HPL’s take on it and got a call from David. He discussed his concern over the amount of silicon in the analysis and recommended I change the fluid to get the contamination out and try to find out where the contamination was coming from. It was super neat getting to discuss this with him! The standard change interval for the Primary is 10k miles. Come to find out, in 2018, HD issued a service bulletin to install a “Primary Breather Tube” to Milwaukee 8 bikes from the factory after that point, and to retrofit that breather tube to all bikes prior to that as a recall. The reason for the breather is the primary chain case would siphon transmission fluid over from the trans case. The breather introduced a contamination path. I’m changing my Primary change interval to every 5k. Pics of the analysis and of the filthy breather.
