As a Side Note, using M1 ESP X4 0w-40, at TX lows 1/2 the year and 105+ highs, wanted a bit more VI and Rod and Turbo, bearing stress protections as I still drive it like my FA20 Turbo'd FRS
Trans is getting full flush with HPL Green (4Gal) was min. order, so I will have leftovers. Per AMSOIL (for my truck) the xfer case listed ATLPK-EA, which is the SAME they list for the AT.
QUESTION: You guys think I'm good to use the HPL Green in the Transfer case?
I am also planning on AMSOIL Sever Gear 75w-110 for stress and heat durability. I will have less leftovers, if I just use 75w-110 for Front and Rear Axles.
So if there is any "DONT DO THAT or you'll blow it up" now is the time to say.
