What's wrong with coil springs?
probably a good idea if they match the coil spring rate with the carrying capacity of the old leaf springs, probably get the best of both worlds as far as carrying capacity/ride comfortWhat's wrong with coil springs?
As long as you keep the tongue weight reasonable it's fine. We tow boats regularly with our 1500 and it does a fantastic job and doesn't drop in the rear much at all. Now, if I had like a skid steer on a float? Yeah, I'd expect it would squat pretty good and airbags would be required.As people have proven with the Dodge trucks (1500, 2500) with coils, you have to have airbags if you want to do real towing. Otherwise they squat horribly. And you can't put a slide in camper in one.
Luckily for most, trucks are a status symbol and will never see a trailer or heavy load
Now we know why truck prices keep rising. People that don't need them buy them.As people have proven with the Dodge trucks (1500, 2500) with coils, you have to have airbags if you want to do real towing. Otherwise they squat horribly. And you can't put a slide in camper in one.
What do you define as "real towing" anyway? Most 1/2 ton's have a payload rating in the 1400-1800 ft lb range. After adding a family of 4 and cargo, you're probably maxed out in the 6000-8000 lb range.As people have proven with the Dodge trucks (1500, 2500) with coils, you have to have airbags if you want to do real towing. Otherwise they squat horribly. And you can't put a slide in camper in one.
Critic-the issue is the manufacturers towing ratings have no relationship to payload. I have stated on Silverado forums many times-that the "sweet spot" for MOST half-tons for towing is between 5,000 and 5,500 pounds. And there are many choices, for example of travel trailers in this weight range. This way you have some payload left. Most guys want to buy a "condo on wheels" because the manufacturer says the truck can tow close to 10,000 pounds-and if they buy a trailer spec'ed this heavy they ultimately get a bigger truck. I have seen this scenario play out over and over again on various truck boards.What do you define as "real towing" anyway? Most 1/2 ton's have a payload rating in the 1400-1800 ft lb range. After adding a family of 4 and cargo, you're probably maxed out in the 6000-8000 lb range.
It's the job of a weight distributing hitch to spread the weight among ALL AXLES to prevent squat. This includes the front axle of the truck and some weight ( 20% to as much as 33%) on to the axles of a dual axle trailer.As far as squatting goes it wouldn't matter if the springs were coils, leafs, torsion bars, metal, plastic (corvette), what matters is the Spring Rate. Higher or lower payload configs will have different spring rates. If it is not an air spring you have to set one rate.
Ride quality could improve with a rear coil vs leaf if its all designed well. Tundra going coils could be really good. Will they be able to match other brands fuel economy is the bigger question.
You're killing me...It appears a massive mega grille is also confirmed, not that that's a surprise.
