2022 Pennzoil 400 at Las Vegas Motor Speedway
Santa Barbara, CA
Start Time: approximately 3:30pm EST on March 6th
Television: FOX @ 3:30pm EST
Radio: PRN @ 3:30pm EST
Race Length: 267 laps (400.5 mi / 644.54 km)
Race Stages: 80-85-102
Track Information: Las Vegas Motor Speedway is a 1.5 mile (2.41 kilometer) tri-oval located in Las Vegas, NV USA.
Cars to the rear: #18-Busch(backup car), #8-Reddick (unapproved adjustments), Hemric (adjustments)
Tire: Goodyear Eagle 18-inch Speedway Radials
Set limits:
Cup: 1 set for practice, 1 set for qualifying and 9 sets for the race
(8 race sets plus 1 set transferred from qualifying)
Tire Codes:
Left-side — D-5120; Right-side — D-5122
Tire Circumference:
Left-side — 2,251 mm (88.62 in.);
Right-side — 2,280 mm (89.76 in.)
Minimum Recommended Inflation:
Left Front — 20 psi; Left Rear — 22 psi;
Right Front — 50 psi; Right Rear — 46 psi
Set limits:
Tire Codes:
Tire Circumference:
View attachment 91752 View attachment 91751
Tuning in.
SammyChevelleTypeS3
$50 site donor 2023
South East USA
Set limits:
Tire Codes:
Tire Circumference:
thanks . I was trying to find the race on Tv about 2 hours earlier....:rolleyes:
bdcardinal
Santa Barbara, CA
What kind of adjustments are they making? I've been seeing this a lot.
The cars were impounded after qualifying so anything beyond air pressure and some suspension settings is an unapproved adjustment. Reddick's crew fitted a new steering rack. Hemric's crew was working on the transaxle cooling system and replaced lines. Custer's team found an issue with an engine part during warmup per Bob Pockrass.
bdcardinal
Santa Barbara, CA
Will be interesting if more teams start running up front as they figure this new car out.
Saw that last week with the 43, 47, and 99 cars up in the fight. I had assumed Penske would have an early advantage with this car being so similar to a V8 Supercar.
Wow. That seems a bit extreme to me. I can understand them wanting fair competition, but if they find an honest issue with the car, they ought to be allowed to tend to it.
bdcardinal
Santa Barbara, CA
The races are long enough that they should be able to recover. Plus when there is an issue with one of the faster cars you can watch them carve through the backmarkers.
bdcardinal
Santa Barbara, CA
🟨 Caution, lap 65. 8 car spins off 4 through the infield. The 78 is the beneficiary, he is 2 laps down and will get one lap back.
