Penzoil platinumFuel isn't that bad, and yes short trips do cause that. If it concerns you use a 30 grade. What did you refill it with.
Probably -- I just posted my Legacy's first oil change UOA, and moly is high there too.Was the 04/30 sample the OEM fill?? Wow the moly
Switch to PP ultra for, slightly, more viscosity and stay with the 6,000 oci.
Guess just like to keep my engine clean? I had almost 270k miles on my focus ST that wasn't burning oil at all then it got totaled. Changed my oil at every 3000 miles on that car once it hit 50k milesOP, why an engine flush at 18K miles on the odometer?
2.5LDo you have the 2.0L or the 2.5L? Just curious...
That's just stupid. If you're changing your oil on time, there is zero reason to introduce a flush product into your engine.Guess just like to keep my engine clean? I had almost 270k miles on my focus ST that wasn't burning oil at all then it got totaled. Changed my oil at every 3000 miles on that car once it hit 50k miles
