Why?The last two oil changes went far too long.
Why?
Yeah, really…why?? OP definitely needs to find source of silicon entry, but it’s been there forever.A good thing the 2.5's are easy on oil. The last two oil changes went far too long.
The Endurance should be more efficient. All of the particle counts I've seen for Amsoil filters are very good, and those filters are pretty much identical to the Endurance. The Ultra seems to produce higher particle counts, especially for smaller particles.I used one Fram Ultra for the entire OCI. I thought of using the Endurance next change, but isn't the filtering more course?
I'm guessing that work caused a vacuum leak somewhere.I have also had the Thermo Control Valve replaced at 99,737 miles. To replace the part they had to remove the intake manifold.
FWIW, the one particle count I've seen for an OEM Tokyo Roki filter was 16/16/13, which is pretty respectable. Not as good as an Endurance would do, but much better than the WIX and better even than most PCs I've seen for the Ultra.The particle count I got on one of the early samples was using the Royal Purple filter which is the same basic filter too.
The other I believe was the Wix.
IRON, look at your report!Why?
Your feelings about extended intervals don’t trump the data. OP has gradually worked his way up in mileage, and other than the silicon level there’s nothing wrong here.I completely am against extended intervals like this but overall the oil held up good.
I do 5k intervals, and let me know when he reaches 300,000 miles following those intervals. If you think UOA tells the full story you are misinformed.Your feelings about extended intervals don’t trump the data. OP has gradually worked his way up in mileage, and other than the silicon level there’s nothing wrong here.
Go ahead and change your oil every 3k. This Subaru is obviously doing quite well at 140k+. If OP gets his silicon source identified and fixed, there’s zero concerns with 20k intervals especially if a C&P of the filter shows no particulates on the surface of the media.
BTW @iunderpressure, have you been servicing your CVT? If so, what fluid?
