Hopefully Grupo Gonher has addressed the ADBV issues with the OE filter they assemble for Nissan,
some times the "umbrella inverts inservice and there is no ADBV function and you will have chain racket at startup. I had the older rogue with the solid cam and was chasing engine racket. The OP engine may have HLA, I have not been able to confirm..
If there is room I would run the Titan v8 filters as you get likely 35-50% more filter area. Nissan had been using the "universal Asian spin on filters" which go on everything Asian BUT Toyota.
The filter mount used to be behind the right side tire. I would just steer the car to the right all the way to access it.
