Changed my oil before I had a new larger turbo installed. Shortly after I did 2 days of HPDE where it got beat on pretty good with sustained triple-digits/near triple-digits and high oil temps so figured I’d have a look at the oil. ~3K on the Liquimoly Molygen 5W40. I expected higher wear metals vs. last UOA from the new turbo b/c that's what I saw last time I swapped the turbo (the 29K UOA) but didn't see them. Just some higher silicon. They primed it per SOP with oil and let it idle for 15 min before driving. I think the oil looks fine or at least on-part with my other data and I’ll go out to 6K or so I think this change. I just used a large syringe I have with some tubing that fit down the dipstick tube – worked perfect for pulling a sample vs. unbolting the belly pan and cracking the drain plug.
