K
Karstgeo72
My forum username got goofed so I'm TiGeo from before. Did a shorter interval b/c I needed to get the tires rotated and some other service at 40K so said screw it - plus with FCP's lifetime replacement, it cost me $21 in shipping. Continues to look fine to me - the viscosity is lower than I would have expected over such a short interval. I changed out to an open-element intake with a K&N and continue to see low silicon. Driving was somewhat spirited over this interval with several hooning runs to the mountains with groups where the engine was pushed into sustained high rpms for long periods.
Note that since Molygen has "MFC" friction modifier that contains tungsten, I had that analyzed for as well.
My car runs the larger GTI IS20 turbo and other hardware bits plus software that pushes the original 170hp north of 300, boost peaks around 22.5 psi and oil temps sit around 220 most of the time when driving on the highway/hard. I also run about a 30% ethanol blend when possible which gives me less timing pull/more advance. The car runs like a top. I also have been using the Liquimoly Proline engine flush that last few times, can't hurt.
