Any way of knowing how many hours are on the engine?
Please do share again on this. I am curious if it may apply to other turbo 'eco' type engines.I have been using Mobil 1, 10w-30EP with 5000 mile OCI's in my 2011 3.5L Ecoboost since new. 120K so far, no rattles, no turbo issues, no smoke, not even a hint of trouble. It's as smooth and powerful as it was when new. But, I had a bit of inside info that lead me down this path. I've shared the information here on BITOG ever since.
Synoypsis:Please do share again on this. I am curious if it may apply to other turbo 'eco' type engines.
Thank you for the recap. I fan along pretty much the same thinking. However, my changes were at 5k max. There is no way I'd go farther on an EB type of engine. Maybe VWs can, but even then, I can't see myself ever doing it.Synoypsis:
Chains live longest in a true 30 viscosity oil. VII do not fully qualify. A 0W-30 does not provide the same chain life as a straight 30 of similar quality.
Fuel dilution non-evaporated components replace oil consumed, with non lubricants, reducing the oil's properties. (ever wonder why oil level never decreases?)
Raw fuel dilution reduces viscosity, and therefore chain and phaser life
Particulate matter is bad for chains and phasers
EB equipped vehicles typically contaminate the oil by 4000 miles. I'd rather not drive more than an additional 1000 miles with high particulate loads and high fuel dilution.
My thinking: 10,000 OCI's is 6000 miles on fully contaminated oil per change. 5000 is 1000 miles per change.
At this point, it should be clear to anyone who cares to look, the EB engines that fail early were not maintained at the severe service interval.
Note: It's also good to recognize that oil pressure rise can at times be slower, leading to start up chain and phaser rattle. Filter drainback seals can affect this, as can base viscosity.
Note2: Change EB plugs regularly. The boost is hard on plugs and misfires lead people to believe they have other problems.
Note3: Early EB F150's need a small hole drilled in the bottom of the intercooler. This prevents liquid buildup and subsequent engine slugging.
Note4: I simply change oil on the 5's. 5000, 10,000, 15,000, 20,000 etc.
I think the brilliant plan was to use connectivity to inform "Ford-central-planning" of impending problems, then to complete said repairs prior to the catastrophe.And supposedly Ford’s new CEO who’s coming in from Toyota wants to slay warranty costs.
you can’t fix mechanical flaws with code. A local transit agency bought a few fleet of trains from Bombardier and they had issues they tried to fix with code. Boeing tried to use software to overcome a airframe’s limitations(737 Max). It’s hit and miss as a approach.There is no question that software can find patterns that might not be evident to casual observers. But to rely on such tactics with machinery that has relatively few sensors is not a valid plan.
