Don't change the air filter too often. The bulk of particulate (90%) which will pass in its lifecycle, does so in the first 10% of its life. If you're into smart, data driven decisions, then get an intake tract vacuum gauge and follow it; ignore the calendar and odometer for the air filter.
OK - I understand. But why pay for the UOA data and then eschew what it's telling you?
There are a few choices you have, given the results you've seen in the UOAs:
- stay the course; it's working, but wasteful. You're doubling down on waste when you throw out good oil after ignoring data you paid for.
- extend the OCIs; get the value from the fluid, as well as the data you paid for
- use a less expensive lube and stick to 10k miles
The 2GR-FE and 2GR-FKS are very easy on oil. (I have one of each, in my ES350s). The macro data from many hundreds of samples I have in my database indicate, as your UOA does, that wear rates are very desirable in these engines; they are not picky about lubes. You could get the same wear rates from using the basic ST 10k mile rated lube if 10k miles is your self-imposed OCI limit.
Do as you see fit.
