Thank you.And yes, I know a 30 or 40 would work. But the requirement is VW508.00, whether you, I, or anyone else likes it or not.
ARCOgraphite said:There is no reason why a M1 EP or Castrol Edge Extended Performance wouldn't do the trick.
Plausible indeed.
People really need to stop telling people to avoid this spec. In the US, this LOW-Sap oil has everything to do with the carbon/valve build-up and damage to the CATs. There are well documented several warranty claims on low mileage VW engines that called for 504/508/507 specs. Mainly triggering Engine lights due to the emissions system. Anyone look at the tailpipe of a low-saps VW cert oil on new engine requiring Low-saps After 8k miles??? You barely see any carbon build-up especially on 93octane. In fact that's why all VW dealerships are being forced to stoke the correct spec oils. Hence the switch to Mobile from Castro's and the dealers now stocking the right stuff. In Europe, the Low-Saps protects the Particulate filters.
My buddies 2.0T tripped an engine light after 20K. Checked the history, they were putting regular Castro's 5w-30 and dumped to much carbon in the system!
Só please stop giving bad advise on the VW spec..it is imperative. By the way, the green dye burns away after a few hundred miles...so it's not for warranty purposes
That specification is not anymore strict on SAPS then VW504.00/507.00.
Actually, if CBU is main concern as well as CAT pollution, then VW504.00/507.00 in combination with MB229.51 (SA limit less than 0.8%, P limit is 0.05-0.09%, Noack limit 10%) should be used.
Noack limit on VW504.00/507.00 is 13% (rarely any is so high) and SA limit is 1.0-1.5%, while P limit is 0.08-0.15%
In interest of warranty VW504.00/507.00 should be used. In interest of engine performance, MB229.51 should be used.
So, Mobil1 ESP 5W30 will do the trick.
Not sure what exactly your referring to. ALL of the new VW specs are low-SAPS. The only difference is the viscosity. The all have the same goals. Although, the 0W-20 contains an even better base. The VW oils stay in grade throughout the full OCI...think 18K. And some other wear tests VW requires that I would have to research. SÃ .8% is the same on non ESP mobile oils such as Extended Protection and Phosphorus is also low on all the premium Mobil oils. SÃ is only part of the picture. NOAK being so high doesn't matter since it doesn't oxidize.
Plausible indeed.
And HTHS, as 504/507 is still 3.5 cP minimum. 508/509 is lower, iirc 2.6 to 3.5 cP.
Plausible indeed.
You just gave us partially correct run down that pretty much everyone knows here, but you are saying you are not sure what I am referring to?
You can find SAPS limits in all VW specifications, as well as MB, BMW etc. When you find, compare it and you can easily figure out which oil is lower SAPS. VW specifications are not "low" SAPS, they are on Mid to lower SAPS specifications. Also, if you are concerned about CBU, CAT's or DPF/GPF you have to take Noack into consideration, and VW specifications are not as strict as MB 229.51/52.
