I got the factory fill on my JCW analyzed. Doesn't look too bad for a low viscosity oil in a direct injected european engine. I believe this oil is made by Shell.
Code:
MI on Oil 6000
Sample Date 3/17/2017
ALUMINUM 8
CHROMIUM 1
IRON 27
COPPER 20
LEAD 0
TIN 0
MOLYBDENUM 481
NICKEL 0
MANGANESE 12
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 125
SILICON 18
SODIUM 8
CALCIUM 2050
MAGNESIUM 6
PHOSPHORUS 602
ZINC 697
BARIUM 1
SUS Viscosity 54.8
cSt Viscosity 8.72
Flashpoint in °F 405
Fuel %
Antifreeze 0.0
Water 0.0
TBN 2.6
Blackstone's comment was:
We're sure you're having lots of fun with your new JCW MINI, and it's starting off analysis with a good report. Typical wear we've seen from these engines is shown on the far right after ~4,600 miles on the oil. Those averages may change over time since we don't have a ton of samples in the file yet, but it gives a starting point for how this engine might wear in an oil change or two. There's some copper wear-in, but that's normal for a factory oil fill. The TBN is strong at 2.6. Up to 8,000 miles next time is fine, assuming that doesn't interfere with your warranty.
--Matt
Code:
MI on Oil 6000
ALUMINUM 8
CHROMIUM 1
IRON 27
COPPER 20
LEAD 0
TIN 0
MOLYBDENUM 481
NICKEL 0
MANGANESE 12
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 125
SILICON 18
SODIUM 8
CALCIUM 2050
MAGNESIUM 6
PHOSPHORUS 602
ZINC 697
BARIUM 1
SUS Viscosity 54.8
cSt Viscosity 8.72
Fuel %
Antifreeze 0.0
Water 0.0
TBN 2.6
--Matt
