Sorry if bumping this thread after 4 months inactivity is bad form, but I am keenly interested in any EB 3.5 discussion and especially UOA’s. To Tom (the OP), congratulations, you appear to have a well-behaved EB Transit. I can’t tell you how much I wish I had UOA’s like yours. I think you really lucked out getting this used with such an apparently solid engine. I have had all sorts of alarming UOA results, mostly regarding fuel dilution.
I hope you will keep us posted with future UOA’s, though I think there are better options than Blackstone for an engine family known to have fuel dilution problems (not that you do, but a fairly high percentage of 3.5 EB’s do). Now, I don’t know what “high percentage” means, except it is way way larger than 0%, and unfortunately, I am one of the non-0%ers. I’m not even sure EB’s are any worse than any other GTDI engine from any other manufacturer. I may try TestOil lab next, but think at least use Oil Analysers instead of Blackstone. Both TestOil & OA do a “real” test for fuel, and have oxidation & nitration results. That said, I don’t know accuracy of any service, hopefully good. And I admit, Blackstone’s analyser’s text review is better than OA’s…which is pretty clueless.
But you must have had some inkling of this potential problem if you added a catch can. I am considering the catch can approach. I’m thinking, since I am routinely getting 2.5%-4.5% fuel, my can would catch more than 1-2 oz per OC.
Of course, what oil I use, does not cause the fuel dilution, but I’m thinking what oil I use does impact the oil’s resilience to the dilution. (Here comes a flame from DNewton or Blackstone). My first batch of SP generation oil (QS full syn) is in the sump as we speak, with next OC being late spring / early summer. I want to believe it has all sorts of chain and guide-protecting goodness missing in early 2015 Motorcraft SemiSyn (SN-only) and ~2017-18 Pennzoil Plat (some SN, some early SN plus). I never did any UOA’s until ~36k mi which was on the Pennzoil, and results were pretty scary. My use case is 2 changes per yr: 1 change over the summer camping season, which sees 4000+ highway miles, plus 3000+- short trip and/or forest road use. The other change carries it over the winter months which might or might not see any long trips, but this year is mostly 25-100 mile “commutes” to nearby state parks and such…mostly highway. As my mileage has averaged ~11k-12k per year, that means the “winter” change is at a shorter interval (one was less than 3000 because I wanted fresh oil for the camping summer). Current fill is obviously the shorter winter fill, though could be one of the longer winter ones if I take a trip to Sedona or such. I don’t like the Transit version of the Oil Life Monitor, which gives no percentage, just a “jolt” to “change oil now,” for who know what reason (I suspect 1 year or 10,000 mi)…but maybe other Transit owners experience more “intelligence” from the monitor than I have. And personally, from my results, 10k is too long…in my engine. FE isn’t horrible, but Cu is high and other issues with Nitration, water, and some other metals. We‘ll see how the QS does, but I wouldn’t freak out using what your using, if I had results like yours…in fact, I’d be smiling…and giving the one-finger salute every time I passed the Ford dealer…or I don’t know, maybe you should be blowing kisses their way.
PS, i can’t remember whether your year has the 6-speed or 10-speed transmission, though it may not matter…I would look after it’s fluid MUCH more than Ford recommends. My Mercon LV was pretty contaminated at <60k. I did a full flush. If you are capable of DIY trans fluid changes, it might not be a bad idea to do a partial change soon. Freshen it up every so often starting sooner rather than later. 2 back-to-back 4qt drain-and-fills now, and then 1 every 24k would keep things cleaner inside…because you will never be able to service the trans filter without major tear down of the front suspension crossmember. I’m not an expert (obviously) but I chose not to mix fluids…ie, I flushed with genuine Motorcraft Mercon…at a dealer. I’ve been told Amsoil is OK to mix, lots of opinions out there on that topic.
