Finally sent my UOA sample in and it came back a lot worse than I thought it would. I am attributing it to my wife's use of the remote starter in the winter months as she sometimes leaves it idling for quite a while as we get the kids ready for school then again at the bus stop. She has promised not to use it this winter to see if it changes the outcome.
I had major difficulties inputting the data as BITOG changed the site a bit and the code feature is no longer working for me. I will do some research on how I can fix it but after messing with it for over an hour I am fed up
so please check my old post for historical UOA's if you desire.
Previous UOA can be found HERE
Blackstone Comment: The flashpoint was very low this time, showing 5.3% fuel dilution. That's quite an excessive amount of fuel. It caused the viscosity to thin and it very well may indicate a fuel system problem at that level. Keep an eye out for a rising oil level on the dipstick. The fuel contamination didn't seem to have a significant impact on wear levels during this run, but it's best to keep oil changes short for now. The 2.6 TBN shows active additive left, but we don't recommend running longer until we can say fuel is no longer a threat. Check back on fuel in 3,500 miles or so.
Code:
MAKE/MODEL: 2017 Expedition 3.5L EcoBoost
OIL Edge 0w-40
MILES IN USE 5480
MILES 26500
SAMPLE TAKEN 3/1/2020
ALUMINUM 6
CHROMIUM 1
IRON 23
COPPER 12
LEAD 0
TIN 0
MOLYBDENUM 3
NICKEL 0
MANGANESE 8
SILVER 0
TITANIUM 41
POTASSIUM 3
BORON 31
SILICON 12
SODIUM 6
CALCIUM 2175
MAGNESIUM 80
PHOSPHORUS 768
ZINC 905
BARIUM 0
SUS VIS 210?F 56.8
cSt @ 212?F 9.3
FLASHPOINT F 280
Fuel% 5.3
Antifreeze% 0
WATER% 0
INSOLUBLES 0.3
TBN 2.6
