Originally Posted by Gene K
I think some people are addicted to "That's not the way I would do it so it's not right".
It's not 10,000 mi like Toyota 0W-20.
Well it isn't Toyota 0W-20.
Oil Life Monitor / Timer goes off at 5,000 mi so ignore it. What happened to follow the OLM?
The short change is causing excessive wear.
I see that. Looks catastrophic based on that UOA.
Off-Road Use with oversized tires and 4.88 gears may not have been considered part of the 10,000 mi Toyota recommended OCI.
Except for the TBN the oil is within VOA parameters. I don't know what else you guys can ask for. Does the oil have another 3,000 and possibly 5,000 in it? Most likely. Another alternative would be to use conventional SuperTech for 5,000 mi changes but really with a $2.00 per 5 qt difference in price is it really a huge deal?
If I had posted the exact same results with a 3.5 Ecoboost I doubt a single person would have said run it 10,000 mi like Ford recommends and ignore the OLM if it goes off earlier.
Couldn't agree more. I don't know why people are complaining about "wasting oil". Lol.
I also don't buy the frequent oil changes causing wear. ...†...‚
I've been doing 3k oil changes on my last 3 performance engines and the UOA results are AMAZING, considering how much abuse those engines got. You guys are crazy to say otherwise and any testing or "proof" is flawed in my opinion.
Sure if you keep drying starting the engine after an OC with an empty oil filter, a cold engine and taking it for a spin right after, yea, there will be extra wear. But if done correctly, there ain't a chance in [censored] that New oil is WORSE then old oil. 🤨...’🤦ðŸ»â€â™‚ï¸
