2016 Subaru STI 25xxx miles, 3300 mile uoa Castrol edge euro 0w40 w/ Oem filter
Southern California USA
Daily driven 7 mile each way to work, occasional long trips, multiple redlines and high revs due to the short gears and turbo lag (when warm of course). Flashpoint did a lot better here than in my Direct injection m4 with the same GC 0w40. Also running a catch can as the only mod, stock everything else.
Great report. Sheared some.
As expected from an EJ25T motor, known oil shredders from what I've seen at least. However better than my M4 like I mentioned which sheared / fuel diluted the same GC 0w40 down to 10.27 @ 100c w/ a flashpoint of 380F in 1200 less miles than the STI used the oil for. But for the STI the 0w40 seems like a good oil to use on 3500 mile drain intervals. 20-25$ oil per oil change is hard to beat!
Did you stay with Castrol in M4 or you moved?
