2016 FLTRU Amsoil MCV 20W50, 5032 miles
Illinois
I rebuilt engine over the winter.
!0,000 miles on rebuild. Fuel Moto 107, Wood 777 cams, Level B heads and lower end done by Darkhorse. 128.5ft.lb. torque
Samples 13 and 14 were from rebuild. Sorry for the small print not sure how to fix it.
Similar engine mods to what I want to do with my 2008 FLHT… how’s it roll out compared to stock? The TBN hangs on incredibly… are all your samples Amsoil MCV?
Power is impressive. I downshift a lot less now while pulling a trailer. I will do this to the next bike much sooner because it's such a blast to ride.
Yes, all samples are MCV.
Thanks for the heads up on VIN. Probably should have covered it up.
You will have a blast when you do the engine mods. I had an 08 FLHT also. Crimson Red Sunglow.
I put everything together. Fuel Moto ported the heads and Darkhorse did the lower end. I installed the tune from Fuel Moto to complete the 3 heat cycles and brought to a local tuner.
