Huh? This is more accurate then trying to guess when the fluid is at the correct temperature for an accurate reading and one side of the dipstick always shows a different level than the other on old dipstick transmissions.
I have done it both ways on a 2015 Altima strippie. The dipstick seems to work fine on this car; I tried and checked it after the dribble level set.
In fact, I now use the MityVac to suck it out (3.5 to 4 qts) and replace approx the same; drive and check. Adjust as necessary.
I service this Altima a lot, because it was an ex-Hertz high mileage vehicle and those CVTs have been problematic.
You do add fluid throught the dipstick tube on these cars...
The fluid was horrid on the 1st drain; I did the first 2 services back to back with oil changes. Fluid seems pretty good now with 161K miles on the clock. Nice car, actually.
The dipstick is a Nissan part; they used on on the same car in prior years.
