2015 Lexus NX 200t - New turbo using TGMO 0W-20?
Burlington, Ontario, Canada
This is an all new engine from Toyota and the first turbo in a Lexus. It's a 2L four rated at 235 hp and 258 lb.-ft. Sound similar to the BMW N20 turbo four. The new small SUV it's coming in should be in dealers showroom this fall. I asked my local Lexus dealer what oil was specified for the new engine and I was told "probably the TGMO 0W-20" but they don't have any technical info yet. I suspect that's the oil that will be specified. If BMW can spec' a 0W-20 for their own turbo four then I'm sure Toyota will: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3407588/1
Southeast Alabama
The Hyundai/KIA 2 liter turbo 4 is rated at 274 HP - 264 HP & 275 - 269 Foot Pounds of Torque depending on application and requires 5W30 with 264 Hp versions and 5W40 with the 274 HP version I understand. One would think that a thicker oil than 0W20 would be used in a turbo application?
CATERHAM
Yes thinking conventionally, "one would think that a thicker oil than 0W-20 wold be used in a turbo application," but a 0W-20 will work as has been specified for the BMW N20 turbo as an option. It's not the first time a 20 grade has been spec'd for a turbo engine. Ford has in the recent past as has Hyundai. In the Hyundai example cited above 5W-30 is what's specified, 5W-40 is just optional.
Chicago, IL
It might be the DI of the Hyundai motor that needs the thicker oil, although if I remember correctly, the BMW N20 is DI, and the the Lexus has some kind of DI/Port hybrid thing.
Is the 20wt robust enough? Maybe engineering is getting ready for lower weights, say 16? Prove a 20wt in turbo and you are laying the path to even lighter.
OVERKILL
$100 Site Donor 2021
Ontario, Canada
If the engine is designed for it, sure thumbsup
'Stralia
I'm hoping that the Ford and BMW engineers cited in this thread did their homework when designing this Toyota engine...
OVERKILL
Ontario, Canada
LMAO!!! grin
Ottawa, Ontario, Canada
Dragging this one up... From the NX200T manual: "Use Lexus approved “Toyota Genuine Motor Oil SAE 0W-20 for Direct Injection Turbo Gasoline Engines” or equivalent to satisfy the following grade and viscosity. Oil grade: “Toyota Genuine Motor Oil SAE 0W-20 for Direct Injection Turbo Gasoline Engines” or ILSAC GF-5 multigrade engine oil Recommended viscosity: SAE 0W-20" So did Toyota come out with a revised 0W-20 for this engine, or are they now referring to their good-old TGMO as “Toyota Genuine Motor Oil SAE 0W-20 for Direct Injection Turbo Gasoline Engines”? If so, do we have to call it TGMO-DITGE? smile
MA, Mittelfranken.de
It will last through the warranty that for sure. Toyota will get CAFE credits that's also sure. What happens to it after that is your problem.
Quote:
BMW Modell 220i Coupe (N20 - F22 - 135kW) (2 Series) Motor BT Jahr 2013- Mobil 1 ESP Formula 5W-30 Anwendung Empfehlung Kapazität (l) Motor (BT) (N20) 1. Wahl Mobil 1 ESP Formula 5W-30 (a) 5.0 2. Wahl Mobil Super 3000 XE 5W-30
And another.
Quote:
BMW Modell X3 28i xDrive (N20 - 180kW) (X3 Series) Motor BT Jahr 2011- Mobil 1 ESP Formula 5W-30 Anwendung Empfehlung Kapazität (l) Motor (BT) (N20) 1. Wahl Mobil 1 ESP Formula 5W-30 (a) 4.8 2. Wahl Mobil Super 3000 XE 5W-30
OVERKILL
Ontario, Canada
Originally Posted By: edyvw
Did I miss something, but since when BMW is using W20?
BMW came out with "FE" versions of a couple of their specs in the last while and I believe it is the more recent incarnation that has an xW-20 as a part of it. Nothing wrong with using a 20-weight if the engine is designed for it. If BMW has taken the effort to ensure it works, I'm sure it works perfectly fine.
Kendall, FL
Any proof that your scinism holds water with this particular pairing? I can appreciate your dislike for 0w20 but your last entry is boardering on fear mongering.
Colorado Springs
No thanx. Nothing below 3.5cp.
