Originally Posted By: Jon
My apologies for the unclear phrasing in my previous response. I'll try again here:
I was doing fairly regular UOAs on this vehicle as it was new. It wore in so well that by 15,000 miles or so it was basically "wear-free" between oil changes. I wasn't always the nicest to it, either.
That would refer to the "before" part.
Then I noticed it had a very slight unevenness at startup, but I'm very sensitive to such things. Further investigation revealed the fuel dilution.
Once the repair was complete, I changed the oil and ran a normal OCI + UOA. Wear levels returned to their previous "very very low" state. This is the "after" part.
In summary, it want:
In further response to another question you ask, "Was wear lower with 4% fuel dilution?" No. It was not. It was high for *this* vehicle since it already had a nice history of low wear. Compared to a different vehicle it may have been considered "normal". Does that make sense?
Except for some real stinkers ('07 and '08 inline 4 cracked heads, etc..) Honda engines are - by far - my favorite. Especially with RLI fluids. And they seem to have fixed their transmission issues around 06 or 07.
I will say that 1.9% fuel dilution in 1,000 miles seems very high to me, but what do I know about this (answer: only what I read on the Internet). Best of luck!
As a side note, maybe somebody can explain to me why changing the viscosity of a fluid changes the way it reacts chemically to fuel (a solvent). I would think additive package and overall chemistry would be a far more important consideration in such a situation.
Thanks for the clarification. I don't think changing viscosity makes a big change the way it reacts to a solvent. The viscosity discussion here centers around the notion that fuel thins oil and thinner oil has a harder time maintaining the hydrodynamic wedge that separates bearings and the like. So a heavier oil theoretically can absorb more fuel dilution and still provide protection.
Someone may point out that oils with a wide viscosity range probably contain more viscosity index improvers than those with a narrow range. And these VIIs apparently can be permanently damaged by fuel, so the more VIIs, the more effect fuel dilution has. But Ford changed some DI EcoBoost engines from 5w-20 to 5w-30, apparently in response to fuel dilution. So in this context, heavier oil benefits seem to outweigh extra VII detriments. I guess.
