Originally Posted By: dnewton3
Well obviously the 10k mile OCIs are well suited for your rig; wear rates are dropping nicely as the engine matures.
I'd stick to that plan and just enjoy the results. It would be nice to get more value (longer OCIs) out of the lube, because the likelihood is that your tossing lube that's not anywhere near expended, but I do understand the constraints of warranty concerns.
If I hadn't seen a handful of these engines have issues on another forum, I would totally do a 12-13k oil change, do another UOA, and see if I'd be alright doing 15k - I suspect I would be OK doing this... but I don't want to get into the issue of "whelp, it blew because you didn't change the oil" via the dealership.
Once I pass 100k, or maybe even once I get closer to 100K, I'll go this route.
Originally Posted By: Panzerman
You are getting decent numbers, but WOW. 5w30 oil in a Diesel for almost 10,000 miles. I am impressed. Ill admit, I couldn't do it. How many quarts does it hold?
It's 10.5 quarts. I've never really been concerned on the oil itself - and this shows it's holding up just fine.
Originally Posted By: spiderbypass
The amazing thing is that is a low saps oil that starts with about 6tbn so you're protecting diesel particulate filter and the engine nicely . Amazon also sells the oil at a good price.
Yes, I do buy my oil off Amazon - it's hard to find anywhere else, and if you do it's quite a bit more. I laugh, as it's cheaper to just buy two cases on Amazon than it is to buy 1 case and 5 quarts.
