Hi guys and gals, here's the very first UOA from my Brand Sparkling New 2014 Mazda 3 Hatchback.
The factory fill ( Mazda's 0w20 ) was dumped after 1,000 miles of hard city driving and Mobil 1 0w30 AFE was poured in and sampled after 3,000 miles on the oil ( 4,000 miles on the engine ).
I decided to check on the condition of the oil after only 3,000 miles in order to see if my relatively short city sprints are causing fuel dilution with this DI engine. Although I'm glad to see that no serious amount of fuel is present, I'm also wondering what lowered the viscosity...?
When I choose to run the 0w30 instead of the factory recommended 0w20, I did so because of my location ( sunny Florida ) and the fact that the engine is already beginning to be modified ( aftermarket intake and exhaust were installed @ 2,000 miles ) so the car is driven in a VERY spirited manner 90% of the time, as I constantly push the 2.0L engine to deliver the advertised 155hp / 150tq at Redline to get me from point A to B in a hurry.
I don't see any effect on gas mileage with the thicker oil, and even with the abusive driving, I'm averaging 27-33mpg with 70/30 city / highway sprints around town.
Anyway, this oil was drained when the sample was taken as it's part of my early flush procedure ( change FF @ 1,000 miles and then another oil change after 3,000 miles ) in order to flush out the break-in shavings. I plan to run the current fill of M1 for 5,000 miles and resample and go from there based on the results, although I'll most likely stick with 5k OCIs while the engine is fresh.
Vehicle:
2014 Mazda 3 Hatchback i Touring w/ tech package & 6 speed manual tranny.
Engine:
2.0L Skyactiv DI 4 banger.
Engine oil capacity:
4.5qts
Oil type:
Mobil 1 0w30 SN formula from Walmart in a 5qt jug.
Oil additives:
None
Gas Additives:
Redline's Fuel System Cleaner in a small maintenance dose about midway into the OCI (just for the heck of it)
Make up oil added:
None
Oil filter:
Mazda OEM made by Toyo Roki in Japan
Air filter:
OEM Mazda filter during the FF and then a dry AEM cone air filter after that.
USE: city / highway @ 70/30. I was redlining and running the car HARD as I always do with all my vehicles. Sample was taken after a typical short city drive of 20-30 minutes to mimic actual daily use.
Code:
OIL Mobil 1 SN formula 0w30
MILES IN USE 3,079 miles
MILES on unit 4,084
SAMPLE TAKEN 02/23/2014
Make up Oil 0
Universal Average
ALUMINUM 3 3
CHROMIUM 0 0
IRON 8 10
COPPER 8 6
LEAD 0 0
TIN 0 1
MOLYBDENUM 138 179
NICKEL 0 0
MANGANESE 0 0
SILVER 1 0
TITANIUM 0 1
POTASSIUM 1 2
BORON 90 88
SILICON 14 14
SODIUM 3 25
CALCIUM 1245 2073
MAGNESIUM 684 264
PHOSPHORUS 598 704
ZINC 674 798
BARIUM 2 1
Values Should Be*
SUS VIS 210ºF 52.6 54-67
cSt @ 212ºF 8.05 8.5-12.4
FLASHPOINT ºF 445 >385
Fuel %
Antifreeze 0.0 0.0
WATER 0.0
INSOLUBLES TR
TBN 4.7 >1.0
TAN 3.0
As always, comments are much appreciated.
Vehicle:
Engine:
4.5qts
Oil type:
Oil additives:
None
Gas Additives:
Make up oil added:
None
Oil filter:
Air filter:
Code:
MILES on unit 4,084
Make up Oil 0
Universal Average
ALUMINUM 3 3
CHROMIUM 0 0
IRON 8 10
COPPER 8 6
LEAD 0 0
TIN 0 1
MOLYBDENUM 138 179
NICKEL 0 0
MANGANESE 0 0
SILVER 1 0
TITANIUM 0 1
POTASSIUM 1 2
BORON 90 88
SILICON 14 14
SODIUM 3 25
CALCIUM 1245 2073
MAGNESIUM 684 264
PHOSPHORUS 598 704
ZINC 674 798
BARIUM 2 1
Values Should Be*
Fuel %
Antifreeze 0.0 0.0
WATER 0.0
INSOLUBLES TR
TBN 4.7 >1.0
TAN 3.0
