Imadentguy
Thread starter
- Joined
- Nov 21, 2020
- Messages
- 140
Ooooft…. Thank you for the reply and information! I will pop it open and take a look round in the unit.TIPM is probably getting moisture or has corrosion. I know they had a problem with fuel pump so there is a add on relay to convert relay from TIPM to external. Some say dealers will fix for free but that was couple of years ago. Dealers had everything. Here's the story.
Chrysler recalling nearly 189,000 SUVs
Automaker needs to fix a fuel pump problem that can cause the vehicles to stall.www.usatoday.com
