Originally Posted By: itguy08
Originally Posted By: SteveSRT8
A couple of corrections are in order.
Number one, my trans rebuild was completely voluntary and WAS NOT SLIPPING. Might want to work on that reading comprehension Mr. Smart guy above. Many folks drive their car years like mine and would never know there was an issue. This is a Merc unit known for durability even in ridiculous high power applications.
I think my reading comprehension is just fine. Here's your thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3463592/1
Here are your own words:
Quote:
Due to my background I am extremely observant while driving my car. Recently noticed a very slight delay in my 2-3 shift. At normal speeds most would not even notice this, but I did.
I also believe in being proactive rather than waiting. So I saw my German trans guy and we drove around with the scan tool for a while. The diagnosis was worn clutches on 3, the trans had the pressure jacked to the limit trying to complete the shift quickly.
I'd say a delayed 2-3 shift, with pressures at the max is a slipping transmission. That would be the same if it were a Ford, GM, JATCO, Aisin, ZF, Mercedes, or Mopar.
Then yet again you'd be wrong. No slipping at all, and that throws a code anyway which this unit never did. The pressure was actually at around 80% of maximum, which is higher than usually needed, and could only be determined by an experienced tech with expensive diagnostic equipment. The ONLY reason to rebuild was the nearly unnoticeable delay from 2-3, as stated specifically in the post referenced, which is not normally noticed by most folks. I CHOSE to service the unit as I am going to the track yet again with this car.
I have been to road courses since I was a kid, and done extensive drag racing as well. Never have I or others with even more experience seen a car as durable as this one at the track. The only thing it needs is tires, regularly. When others have a similarly performance oriented and capable vehicle with this kind of history and mileage I would be interested to hear their comments. I still see nothing to indicate that there is anything wrong with individual Chrysler products, only a few lemons which can easily be blamed on poor stealerships as they can't/won't fix them.
Better stick to IT, your trans diagnostic skills are a bit off. Since the word "slipping" was never used either you may want to examine your own bias' first.
No one cares about history, it's a new world of great cars and trucks out there. Stretch a little and get something out of your comfort zone. You might like it.
Plenty of Mopar owners here and elsewhere seem to agree...
