I have an issue with my 2017 Pathfinder, and I've seen the same problem on other newer nissans but few and far between with no fix. So weather doesn't matter, doesn't matter if the engine is cold or warm, doesn't matter if Ive been using 93 or 87 octane, or how much gas is in it.
When going to start (push button) it'll occasionally crank strong for several seconds and hover around 250rpm and shake because it's trying not to stall out. It seems like its still cranking once its at about 250rpm. It'll do it for a good 3 seconds. If I mash the throttle it'll rev to life. It's never failed to start but it does this every once and a while.
I removed and cleaned the throttle body and maf sensor but it doesn't seem like those. Reset the battery overnight. Battery is good, never low. Still does it if I hold the brake first to make sure the fuel pump is set. Definitely a fuel or air problem but nobody, including myself and Nissan knows what it is!
