- Joined
- Feb 28, 2010
- Messages
- 1,663
I like this oil much better in this particular application vs. the Pennzoil Ultra 5w40. People can say "oh you used the SM or the SN" whatever, it carried the same approvals that I needed either way. What I learned is the Mobil 1 0w40 that cost me $23 for 5 qts at Walmart IMO held up better.
The values on the Left are Mobil 1 0w40 after 3300 miles, the values on the right are Pennzoil Ultra 5w40 with 3100 miles. The Center are just average values of oils in the same weight.
I plan on going 5k then will check again.
2013 VW GTI 2.0T
Of Note, I do know the Pennzoil Ultra has lower SAPS than the Mobil 1 and was curious if the SAPS really play a factor in the Intake Valve Deposits known on this TSI engine. So I emailed Redline about their new LOW SAPS oil for my VW. I got a response back stating they didn't recommend the LOW SAPS and to use their regular 5w30. I replied back telling them the story about the Intake valve deposits and SAPS, Redline replied back stating they will check with their cheif chemical engineer and see what he thought. Redline did write back and stated that the Chemist there did not believe that SAPS or ASH played a major role in the Intake Valve Deposits. Since the SAPS is around .8 for Castrol 5w40 and the Pennzoil Ultra Euro 5w40 while the Mobil 1 is around 1.3 I thought it was a note to ask.
I did not request a TAN on the Pennzoil Ultra sorry guys, but did get it for the Mobil 1. Thoughts?
Jeff
2013 VW GTI 2.0T
Jeff
