I just got back the next sample from my Golf R. This car is set up with an APR Stage III kit with runner flaps deleted and an additional low pressure fuel system upgrade. This setup is supposed to be good for ~450hp at the crank. This one is looking much better than the last couple on Motul Specific. These wear numbers look solid for a young FSI engine, and it managed to shear down only one grade, rather than 2, in only 200 fewer miles. I've got the same stuff in the sump again now and will shoot for closer to 5k miles this interval based on these results.
The oils here are:
Motul X-Max -w40
Motul Specific 505.01
Code:
MI/HR on Oil 4353 4555 6348
MI/HR on Unit 19498 15145 10590
Sample Date 08/07/15 03/29/15 11/24/14
Make Up Oil Added 0.5 qt 0 qt0 qt
ALUMINUM 3 5 4
CHROMIUM 1 1 1
IRON 40 50 52
COPPER 3 4 8
LEAD 0 0 0
TIN 0 0 0
MOLYBDENUM 5 5 26
NICKEL 0 1 1
MANGANESE 1 2 2
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 0 2 1
BORON 46 38 47
SILICON 6 6 11
SODIUM 5 4 4
CALCIUM 2373 1727 2550
MAGNESIUM 14 17 23
PHOSPHORUS 821 663 845
ZINC 968 802 988
BARIUM 0 0 0
SUS Viscosity @ 210°F 64.8 57.8 60.5
cSt Viscosity @ 100°C 11.56 9.58 10.36
Flashpoint in °F 370 340 325
Fuel % 0.8 1.8 2.5
Antifreeze % 0 0 0
Water % 0 0 0
Insolubles % 0.3 0.3 0.3
TBN 4.6 3.4
Blackstone's comments were:
MATT: This sample does indeed look better. Iron is at the lowest level we've seen so far. Of course, this is the shortest oil run we've seen too, so that explains some of iron's improvement, but the steel parts did leave behind less metal per mile here than last time, so that's definite progress. Fuel at 0.8% is progress as well and this small amount isn't indicative of a fuel system problem. Rather, we're probably just looking at a little fuel from normal use like idling or taking the sample cold. The TBN is 4.6, showing plenty of active additive remaining.
--Matt
The oils here are:
Motul X-Max -w40
Code:
ALUMINUM 3 5 4
CHROMIUM 1 1 1
IRON 40 50 52
COPPER 3 4 8
LEAD 0 0 0
TIN 0 0 0
MOLYBDENUM 5 5 26
NICKEL 0 1 1
MANGANESE 1 2 2
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 0 2 1
BORON 46 38 47
SILICON 6 6 11
SODIUM 5 4 4
MAGNESIUM 14 17 23
ZINC 968 802 988
BARIUM 0 0 0
Fuel % 0.8 1.8 2.5
Antifreeze % 0 0 0
Water % 0 0 0
TBN 4.6 3.4
--Matt
