2013 Ford Focus ST, purchased November, 2013. My first UOA here:
http://www.bobistheoilguy.com/forums/ubb...il_#Post3066286
This post reports my second UOA.
Car is a daily driver with about 70:30 city:hwy with an occasional rush of turbo thrown in for good measure. No additives added during the whole run. Also a K&N drop-in filter. Engine is a direct-injection variety.
Viscosity and flashpoint were both slightly low and out of spec. Fuel was present, albeit at the detection limit only. Seems like my car likes PP over PU? LOL! No seriously, I'm sure both oils are fine for this car. But given the unavailability of PU here in Canada, I'll just stick to PP. Your thoughts? Should I go no further than 14,000 km between changes or go back to 12,000?
Regards,
Andrew
Code:
Make/Model 2.0L GTDI EcoBoost I-4 engine
Fuel Type: Gasoline
Additional Info 2013 Ford Focus ST
Oil Type and Grade Pennzoil Ultra 5W-30
Oil Use Interval 13,949 km
MI/HR on Oil 13,949 11,753 km Unit/Location Universal
MI/HR on Unit 27,042 13,093 km Averages Averages
Sample Date 03/06/14 7/6/2013
Make Up Oil Added 0 qts 0 qts
Aluminum 6 9 9 5
Chromium 1 1 1 0
Iron 17 22 22 13
Copper 37 65 65 4
Lead 1 3 3 0
Tin 2 2 2 1
Molybdenum 61 59 59 61
Nickel 1 1 1 0
Manganese 6 27 27 2
Silver 0 0 0 0
Titanium 2 0 0 2
Potassium 5 3 3 3
Boron 44 18 18 79
Silicon 15 34 34 18
Sodium 5 4 4 36
Calcium 2289 2494 2494 2110
Magnesium 47 12 12 161
Phosphorus 767 725 725 737
Zinc 881 842 842 822
Barium 0 2 2 3
Values Should Be
SUS Viscosity @ 210F 54.5 58 55-63
cSt Viscosity @ 100C 8.61 9.65 8.8-11.3
Flashpoint in F 355 415 >365
Fuel % 0.5
Antifreeze % 0 0 0
Water % 0 0
Insolubles % 0.3 0.2
TBN 3.6 2.4 >1.0
"Your engine is making nice strides in the right direction. Wear metals read lower after a longer interval, so wear-in material is washing out well. Copper was high enough to get a mark, but it should continue to drop. Copper often takes the longest to wash out since it starts out the highest, but it'll probably be low enough to avoid a mark soon. The viscosity and flashpoint were a little low and the two might be related. The flashpoint shows 0.5% fuel in the oil, which might have thinned the oil a bit (both are harmless). The TBN was good at 3.6. Add 2K km to this fill."
Regards,
Andrew
Code:
Fuel Type: Gasoline
Aluminum 6 9 9 5
Chromium 1 1 1 0
Iron 17 22 22 13
Copper 37 65 65 4
Lead 1 3 3 0
Tin 2 2 2 1
Nickel 1 1 1 0
Manganese 6 27 27 2
Silver 0 0 0 0
Titanium 2 0 0 2
Potassium 5 3 3 3
Boron 44 18 18 79
Silicon 15 34 34 18
Sodium 5 4 4 36
Barium 0 2 2 3
Values Should Be
Fuel % 0.5
Antifreeze % 0 0 0
Water % 0 0
TBN 3.6 2.4 >1.0
