dnewton3
Staff member
UOAs on newer equipment are nearly worthless, except to provide fodder for banter (enter BITOGers who are bored ...
Wear metals are skewed by break-in and Si is skewed by sealers, so there is zero ability to make any decent decisions out of this.
That being said, ditch the K&N. I've not seen any UOA that ever showed filtration being "better" with them. And generally, any OEM media filter will flow well more than enough air to sustain solid combustion events over the intended FCI.
If OEM OCIs are the intended exposure (I presume you'll use the IOLM), then ditch the expensive syn too. Any decent qualified dino lube meeting Ford specs will suffice for normal OCI events, and still have PLENTY of reserve safety margin. Your owner's manual calls for WSS-M2C945-A, which is met by a LONG list of fluids, many of which are dino.
http://www.motorcraftservice.com/pubs/content/~WODFOC/~MUS~LEN/41/13focom3e.pdf
page #307
page #307
