This is from a Camaro SS with the 6.2 LS3 engine with manual transmission. Driven for fun and trying not to get any tickets. So far so good. Basically on ramps are a blast as is taking off from stop signs on back country roads where I can see for a long distance. Engine see's red line every time I take it out. Big difference in power over my 91 Jetta TD. I changed the factory fill out at 734 miles as well as the filter and installed AMSOIL OE 5w-30 and a PF48 filter. About 200 miles before I pulled this UOA I installed a Catch Can, and cold air intake from Roto-Fab. Each tank fill up has been BP 93.
Code:
Oil filter used was a PF48 and ran BP 93 octane fuel since purchased new.
OIL OEF 5w-30
MILES IN USE 3,012
MILES 6,998
SAMPLE TAKEN 9/20/14
Spectorscopic Analysis (ppm) ASTM D5185 Mod
Iron 42
Copper 62
Lead 0
Aluminum 6
Tin 4
Nickel 0
Chromium 0
Titanium 0
Vanadium 0
Silver 0
Silicon 16
Boron 194
Calcium 1967
Magnesium 10
Phosphorus 655
Zinc 794
Barium 0
Molybdenum 73
Sodium 1
Potassium 0
Physical Properties
Viscosity @ 40C ASTM D 445 Mod 56.0
Viscosity @ 100C ASTM D 445 Mod 12.3
Viscosity Index ASTM D 2270 * 224
Base Number 5.03
Acid Number ASTM D 974 1.60
IR (Indexing Numbers) JOAP Method
Oxidation 13
Nitration 6
Antiwear 15
Sulfation 19
Glycol 0
Soot (%) 0.0
Single Component Test
Water ppm 230 (c)
Fuel Dilution % By GC* 0.8
Code:
OIL OEF 5w-30
MILES IN USE 3,012
MILES 6,998
Iron 42
Copper 62
Lead 0
Aluminum 6
Tin 4
Nickel 0
Chromium 0
Titanium 0
Vanadium 0
Silver 0
Silicon 16
Boron 194
Calcium 1967
Magnesium 10
Phosphorus 655
Zinc 794
Barium 0
Molybdenum 73
Sodium 1
Potassium 0
Physical Properties
Base Number 5.03
Oxidation 13
Nitration 6
Antiwear 15
Sulfation 19
Glycol 0
Soot (%) 0.0
Water ppm 230 (c)
